After completing the assembly and wiring of the first prototype attitude controller, I put together some arduino code and tried it out in KSP.
The code is fairly simple as it simulates a keyboard with the microswitches of the joystick triggering key presses.
The code still needs a fair bit of work including some form of debouncing and making sure the latency isn't to high
