Example YAML-config repository for Home Assistant with ESPHome under ESP8266
- Ionizing radiation power sensor (Moving Average 5 min)
- Ionizing radiation dose sensor
https://github.com/iotdevicesdev/ggreg20-v3-homeassistant-esphome-example
A project log for GGreg20_V3 Ionizing Radiation Detector
The GGreg20_V3 Ionizing Radiation Detector is a new-generation ready-to-use device with an SBM-20 Geiger tube and pulse counting output
