GGreg20_V3 sensor is added on ESPHome-Devices
A project log for GGreg20_V3 Ionizing Radiation Detector
The GGreg20_V3 Ionizing Radiation Detector is a new-generation ready-to-use device with an SBM-20 Geiger tube and pulse counting output
iot-devices-llcIoT-devices, LLC 12/31/2021 at 20:040 Comments
ESPHome-Devices website is a repository of device configuration templates and setup guides for devices running ESPHome firmware.
The sole idea of ESPHome-Devices is to document all devices capable of running the firmware along with a basic configuration yaml that can be easily copied and uploaded
IoT-devices' GGreg20_V3 ionizing radiation detector module can be found following the link:
https://www.esphome-devices.com/devices/IoT-devices-GGreg20-V3/
