At the end of December 2024, our user from Germany found that the pulse counter (pulse_counter component) in the example YAML code for ESPHome firmware with the ESP32 controller stopped working. Thank you, Kedalux, for paying attention to this and participating in the localization of the problem.
Read the full article at:
https://iot-devices.com.ua/en/esphome-esp32-ggreg20_v3-firmware-pulse-counter-issue-solution/
IoT-devices, LLC
