ESPHome firmware for ESP32 with GGreg20_V3 – solution to the problem with the pulse counter
A project log for GGreg20_V3 Ionizing Radiation Detector
The GGreg20_V3 Ionizing Radiation Detector is a new-generation ready-to-use device with an SBM-20 Geiger tube and pulse counting output
iot-devices-llcIoT-devices, LLC 01/04/2025 at 11:570 Comments
At the end of December 2024, our user from Germany found that the pulse counter (pulse_counter component) in the example YAML code for ESPHome firmware with the ESP32 controller stopped working. Thank you, Kedalux, for paying attention to this and participating in the localization of the problem.
Read the full article at:
https://iot-devices.com.ua/en/esphome-esp32-ggreg20_v3-firmware-pulse-counter-issue-solution/
Rich text editor
