Introducing the New Black GGreg20_V3 Board: High-Voltage Adjustment Upgrade, Quality Control, and Warranty Stickers
A project log for GGreg20_V3 Ionizing Radiation Detector
The GGreg20_V3 Ionizing Radiation Detector is a new-generation ready-to-use device with an SBM-20 Geiger tube and pulse counting output
iot-devices-llcIoT-devices, LLC • 10/03/2025 at 14:22•0 Comments
The new GGreg20_V3 board is supplied in black color. This is probably already the tenth generation, which received an updated circuit for smoother high voltage regulation and limitation of its values. The module also received two stickers: Q.C. and VOID. Read about all this in this article.
Read more:
https://iot-devices.com.ua/en/new-black-ggreg20_v3-board-hv-adjustment-upgrade-and-stickers/
