Code and Instructions on Github
A project log for Pi Closed Captions
A system for adding closed captions to the composite video output of a raspberry pi
theloosearrowtheloosearrow 12/23/2021 at 22:180 Comments
A rough tutorial along with the necessary code to get this setup working has been uploaded to Github:
https://github.com/TheLooseArrow/PiClosedCaptions
On the hardware side its relatively simple: an arduino, an LM1881 sync separator chip, a diode, and a handful of resistors and capacitors:
The software and firmware which consists of python scripts and an arduino sketch can be found on the Github repo.
