Did some more edits on the PCB, including adding an additional I2C breakout header, I chose the Breakout garden pin order for this header.
- Female header would enable users to plug in either some straight or 90degree pins
- Alternately plug in a breakout garden socket
- Enables plugging in the I2C range of Breakout Garden components
- Also enables use of 4trionics ultrasonic sensor
- Alternately you could stick some Dupont cables into it if that's more your jam
