Portable PySpectrometer
Everything you need to run PySpectrometer from Les Wright on a mobile platform
jj
Public Chat
This is a portable Spectrometer based on a Raspberry Pi 4 with with no-ir camera and diffraction optics.
The spectral range is 310 - 760 nm in 640 channels !
Running this software made by Les Writght: https://github.com/leswright1977/PySpectrometer
Ingredients:
-Raspberry Pi 4 (4 Gb)
-TFT: 5" with 800 x 480 pixels
-RPi Cam without IR filter
-8 mm IR Lens
-the cable for the cam is about 15 cm long.
-3d-printed cam & optics holder
-3d-printed case. The back of the case had to been stretched in depth to fit everything in (https://www.thingiverse.com/thing:3679054).
/*-atm with external power bank. ..looking for suitable LiPo and Converter.*/
Now with internal, wireless rechargeable power supply!
Dimensions: 123 x 100 x 40 mm
Based on: https://hackaday.io/project/181144-raspberry-pi-spectrometer
To focus the lens correctly, just use the camera as intended and without diffraction optics and adjust the lens so a sharp picture can be seen. Now insert the diffraction optics, so the red part of the spectrum is on the right side of a picture. Get a red (650 nm) and UV-laser (405 nm) pointer and calibrate the software.
Demo:
* I think i damaged my camera. Random noises appear on ccd (readouts?) sometimes.
TinyPiSpec.stl
Holder for optics and rpi camera
Standard Tesselated Geometry - 6.92 kB - 12/19/2021 at 10:10
Download
  • Adding wireless charging & internal LiPo "powerbank"
    j • 02/21/2022 at 18:42 • 0 comments
    Upgrading the portable pySpectrometer with a LiPo and wireless charging receiver.
    I planed to put those parts into the case:
    Will it fit ?
    Yes !
    Is the cam still okay?
    Yep!
    ... but after 15 mins of usage the StepUp overheats ! - looking for a 5 Amps StepUp now.
View project log
