Now working up the courage to charge the input capacitors to 300v+ and see if we can get 230vac output voltage and power something heavier. Stay advised.
A project log for Grid Tie inverter SMA Sunny Boy SB2500 openlogic
Try to reuse a SMA Sunny Boy 2500 Grid Tie inverter as an off grid inverter
