Drives a resolver and returns the rotor angle at an update rate of 10kHz
Resolver_CAN_I2C.PDFProject schematicsAdobe Portable Document Format - 1.97 MB - 01/03/2022 at 15:57 |
The boards were received after a long delay stuck in Chinese customs
They soldered up nicely and power up as expected
The resolver angle is read as follows:
The firmware has various monitoring functions via a USB serial port as well as an automatic calibration routine to determine the resolver primary to secondary ratio for the best accuracy as well as the phase delay of the amplifier.
