At the beginning I want to mount PCB, screwing it directly. But because of quite big size I change my mind and make aluminum L-bracket to fix PCBs.
To have better contact with ground in electric cabinet I decide to make long screws (piece of aluminum with threaded holes and glued hex screw on one side and piece of threaded rod on other)
