A longer explanation of the completed clock module is forthcoming. A brief technical description of the module is available in the PDF of the schematics. For now the module:
- keeps track of the state through transitions using a d-latch connected as a clock divider
- switches between states using a single push button.
- sends a momentary power on reset signal
- accepts a high signal which when held high, the clock stops ( and holds it's state)
- does not use a NE555 Timer.
This is done with only 3 chips.
