User interface
01/12/2022 at 09:31 • 0 commentsGPIO pin assignment:
GPIO port - pin header:
Fan #1 circuit:
Fan #2 circuit:
PCM Audio port:
USER LEDs:
Buzzer:
User interface
01/12/2022 at 09:27 • 0 commentsGPIO pin assignment:
Fan #1 circuit:
Fan #2 circuit:
PCM Audio port:
USER LEDs:
Buzzer:
Future plans (GEN2.1 and GEN3.0)
01/06/2022 at 02:50 • 1 commentThere are plans to update this project and to implement new features (roadmap for 2022):
GEN2.1:
- mechanical improvements (new PCB dimensions, updated mounting holes position),
- updated GPIO port to be compatible with future designed LCD front-panel,
- designed dedicated push-button controller and power management unit (PMIC).
GEN3.0:
- PoE power supply standard,
- LCD front-panel with 3.5" screen and touch pad,
- fingerprint sensor,
- NFC reader,
- 12VDC power supply,
- 2-port USB hub.
BitPiRat during testing
01/06/2022 at 02:38 • 0 comments#BitPiRat during testing...
CM4 & CM4 Lite - OK
MiniHDMI - OK
Qwiic OLED - OK
User LEDs OK
Buzzer - OK
ETH - OK
M.2 NVMe SSD 2280 - OK
PWM fan EMC2301 - OK
USB 2.0 - OK
MIPI DSI - OKIt seems that so far all the features are working 100%
MIPI DSI 800x480 IPS LCD & Qwiic OLED I2C 128x64:
BitPiRat project - short promo video
01/06/2022 at 02:36 • 0 commentsWe are working with the RunCitadel developers to offer the next-gen platform for full node bitcoin and Lightning network.
https://twitter.com/i/status/1471899920378564613
Testing LCD panels
01/06/2022 at 02:32 • 0 comments#BitPiRat during testing LCD SPI screens.
Waveshare LCD module: 1.3", 240x240 pix, IPS matrix, ST7789 controller.
You can connect lot of different LCD/OLED screens by using interfaces such as: I2C, SPI, MIPI DSI, or MiniHDMI.
So you can also run OS @RaspiBlitz @mynodebtc @RoninDojo
2", 320x240 pix, LCD SPI, ST7789, Waveshare.
Pictures rescaled to the full screen.
During testing by other users
01/06/2022 at 02:30 • 0 comments -
Installed crypto distro - RunCitadel
01/06/2022 at 02:29 • 0 commentsDuring synchronizing bitcoin blockchain and long-term functional tests.
RunCitadel:
https://twitter.com/runcitadel
Setup:
- CM4 Lite module with 8GB RAM,
- 1TB NVMe SSD drive (WD Blue SN550 Series),
- 64GB microsd card (SanDisk Extreme),
- GbE,
- 5.1V supplyOK, 100%, fully synchronized.
Citadel updated to v0.5.17.
Node works stable and without any issues so far. -
3D STEP model (PCBA)
01/06/2022 at 02:25 • 0 comments -
Asembled PCB board
01/06/2022 at 02:24 • 0 comments
