Extruder: Direct Drive - Orbiter F2.85mm Dual Drive extruder by Dr Robert Lorincz
https://www.thingiverse.com/thing:4860182
- This extruder is specifically designed for 2.85/3.00mm filament. The design is well documented and can be replaced with the Orbiter v2.0 if 1.75mm filament is desired for future printing projects
Hotend: 3mm Direct V6-style hotend
- This hotend is directly compatible with the Orbiter extruder
Mainboard: RAMPS/Mega combination
- This mainboard combination was already in my inventory, but is also one of the cheapest and most common boards.
Stepper Drivers: BigTreeTech TMC2208
- These stepper drivers offer stealthchop if run in legacy mode, or can be run in UART mode to fine-tune the stepper current.
LCD: BigTreeTech 12864 Full Graphics Smart Controller
- This LCD panel was already in my inventory. It is an inexpensive LCD screen that will display the information required and allow changes to be made using EEPROM/
