Finished my final exams so I’m able to come back and hopefully finish up this project. Previously I validated all the hardware, so I just need to implement the changes onto some new boards.
The final widget is going to have 1 main board, and several daughter boards that slot in via headers. I’ve done 2/6 boards so far and plan to finish up this weekend. I’ll be using JLC’s smt assembly to conserve my sanity.
Here’s the finished main board to give you an idea of the design. The weird shape of the PCB is to help it slot into a case I'm making.
