It's been a while. But we're back!
The roomba has been doing it's scheduled job for quite a while. And I must say, I'm impressed with the stability of the whole setup.
The battery needed replacing after two years. The roomba also would quit outputting serial data a few times and needed a reset. But it would run beautifully for months at a time!
In the meantime the house got some changes and additional occupants. The complete (digital) infrastructure was also changed,. The mapping service now runs on a different / separate Raspberry Pi. Home Assistant had a complete reinstall and runs on HAOS.
The roomba has been in storage for almost a year during construction works. But when I turned it back on the MQTT-autodiscovery worked like a charm!
It has been cleaning the bedroom now.
I'm running into a few stability now and usability issues which I want to address:
- Unexplained crashes. The ESP would need a hard reset;
- WiFi dropouts (connected to the crashes?);
- Watchdogtimer does not trigger and reset the ESP;
- If "done cleaning" event is not received, mapping algorithm on Pi also won't stop;
- State changes and availability messages are not ideal;
- It needs a "come out from under the bed so I can change your dustbin" routine;
- MQTT-autodiscover should be device-based instead of component based;
So stay tuned! We're back!
