I've found the source code!
It was on an older laptop that got passed along and that I happened to get on my desk for some updates. Anyway, glad to have it. Now I can improve on it, add OTA, MQTT-autodiscover etc.
And try to ignore the big cringe you get when you see your own software from a few years ago :|
#ifndef UNIT_TEST
#include <Arduino.h>
#endif
#include <PubSubClient.h>
#include <ESP8266WiFi.h>
#include <ESP8266WiFiMulti.h>
ESP8266WiFiMulti WiFiMulti;
#include <WiFiClient.h>
#include <WiFiClientSecure.h>
#include <WiFiServer.h>
#include <WiFiUdp.h>
#include <IRremoteESP8266.h>
#include <IRsend.h>
#include <IRrecv.h>
#include <IRutils.h>
#define PIN_IRLED 10
#define PIN_IRSENSOR 4
uint16_t RECV_PIN = PIN_IRSENSOR;
unsigned long previousMillis = 0;
unsigned long currentMillis = 0;
const long interval = 60000;
const char* ssid = "***";
const char* password = "***";
IPAddress mqtt_server(192,168,1,***);
char* message = "";
WiFiClient espClient;
PubSubClient client(espClient);
IRsend irsend(PIN_IRLED); // An IR LED is controlled by GPIO pin 4 (D2)
IRrecv irrecv(RECV_PIN);
decode_results results;
void callback(char* topic, byte* payload, unsigned int length) {
Serial.print("Message arrived [");
Serial.print(topic);
Serial.print("] ");
for (int i=0;i<length;i++) {
char receivedChar = (char)payload[i];
Serial.print(receivedChar);
if (receivedChar == '0'){
Serial.println(" - Off received");
client.publish("LEDStalamp/Response"," - ALL OFF received");
irsend.sendNEC(0xFF827D, 32);
irsend.sendNEC(0xFFE817, 32);
if (receivedChar == '1'){
Serial.println(" - On received");
client.publish("LEDStalamp/Response"," - ALL ON received");
irsend.sendNEC(0xFF02FD, 32);
irsend.sendNEC(0xFF6897, 32);
if (receivedChar == 'U'){
Serial.println("RGB+ received");
client.publish("LEDStalamp/Response"," - RGB+ received");
irsend.sendNEC(0xFF3AC5, 32);
if (receivedChar == 'X'){
Serial.println("RGB- received");
client.publish("LEDStalamp/Response"," - RGB- received");
irsend.sendNEC(0xFFBA45, 32);
if (receivedChar == 'Y'){
Serial.println("RGB OFF received");
client.publish("LEDStalamp/Response"," - RGB OFF received");
if (receivedChar == 'Z'){
Serial.println("RGB ON received");
client.publish("LEDStalamp/Response"," - RGB ON received");
if (receivedChar == 'R'){
Serial.println("RGB RED received");
client.publish("LEDStalamp/Response"," - RGB RED received");
irsend.sendNEC(0xFF1AE5, 32);
if (receivedChar == 'G'){
Serial.println("RGB GREEN received");
client.publish("LEDStalamp/Response"," - RGB GREEN received");
irsend.sendNEC(0xFF9A65, 32);
if (receivedChar == 'B'){
Serial.println("RGB BLUE received");
client.publish("LEDStalamp/Response"," - RGB BLUE received");
irsend.sendNEC(0xFFA25D, 32);
if (receivedChar == 'W'){
Serial.println("RGB WHITE received");
client.publish("LEDStalamp/Response"," - RGB WHITE received");
irsend.sendNEC(0xFF22DD, 32);
if (receivedChar == 'C'){
Serial.println("RGB R1 received");
client.publish("LEDStalamp/Response"," - RGB R1 received");
irsend.sendNEC(0xFF2AD5, 32);
if (receivedChar == 'D'){
Serial.println("RGB R2 received");
client.publish("LEDStalamp/Response"," - RGB R2 received");
irsend.sendNEC(0xFF0AF5, 32);
if (receivedChar == 'E'){
Serial.println("RGB R3 received");
client.publish("LEDStalamp/Response"," - RGB R3 received");
irsend.sendNEC(0xFF38C7, 32);
if (receivedChar == 'F'){
Serial.println("RGB R4 received");
client.publish("LEDStalamp/Response"," - RGB R4 received");
irsend.sendNEC(0xFF18E7, 32);
if (receivedChar == 'H'){
Serial.println("RGB G1 received");
client.publish("LEDStalamp/Response"," - RGB G1 received");
irsend.sendNEC(0xFFAA55, 32);
if (receivedChar == 'I'){
Serial.println("RGB G2 received");
client.publish("LEDStalamp/Response"," - RGB G2 received");
irsend.sendNEC(0xFF8A75, 32);
if (receivedChar == 'J'){
Serial.println("RGB G3 received");
client.publish("LEDStalamp/Response"," - RGB G3 received");
irsend.sendNEC(0xFFB847, 32);
if (receivedChar == 'K'){
Serial.println("RGB G4 received");
client.publish("LEDStalamp/Response"," - RGB G4 received");
irsend.sendNEC(0xFF9867, 32);
if (receivedChar == 'L'){
Serial.println("RGB B1 received");
client.publish("LEDStalamp/Response"," - RGB B1 received");
irsend.sendNEC(0xFF926D, 32);
if (receivedChar == 'M'){
Serial.println("RGB B2 received");
client.publish("LEDStalamp/Response"," - RGB B2 received");
irsend.sendNEC(0xFFB24D, 32);
if (receivedChar == 'N'){
client.publish("LEDStalamp/Response"," - RGB B3 received");
irsend.sendNEC(0xFF7887, 32);
if (receivedChar == 'O'){
Serial.println("RGB B4 received");
client.publish("LEDStalamp/Response"," - RGB B4 received");
irsend.sendNEC(0xFF58A7, 32);
if (receivedChar == 'P'){
Serial.println("RGB W1 received");
client.publish("LEDStalamp/Response"," - RGB W1 received");
irsend.sendNEC(0xFF12ED, 32);
if (receivedChar == 'Q'){
Serial.println("RGB W2 received");
client.publish("LEDStalamp/Response"," - RGB W2 received");
irsend.sendNEC(0xFF32CD, 32);
if (receivedChar == 'S'){
Serial.println("RGB W3 received");
client.publish("LEDStalamp/Response"," - RGB W3 received");
irsend.sendNEC(0xFFF807, 32);
if (receivedChar == 'T'){
Serial.println("RGB W4 received");
client.publish("LEDStalamp/Response"," - RGB W4 received");
irsend.sendNEC(0xFFD827, 32);
if (receivedChar == 'a'){
Serial.println("WHITE+ received");
client.publish("LEDStalamp/Response"," - WHITE+ received");
irsend.sendNEC(0xFF28D7, 32);
if (receivedChar == 'b'){
Serial.println("WHITE- received");
client.publish("LEDStalamp/Response"," - WHITE- received");
irsend.sendNEC(0xFFA857, 32);
if (receivedChar == 'c'){
Serial.println("WHITE OFF received");
client.publish("LEDStalamp/Response"," - WHITE OFF received");
if (receivedChar == 'd'){
Serial.println("WHITE ON received");
client.publish("LEDStalamp/Response"," - WHITE ON received");
if (receivedChar == 'e'){
Serial.println("WHITE 25% received");
client.publish("LEDStalamp/Response"," - WHITE 25% received");
irsend.sendNEC(0xFF08F7, 32);
if (receivedChar == 'f'){
Serial.println("WHITE 50% received");
client.publish("LEDStalamp/Response"," - WHITE 50% received");
irsend.sendNEC(0xFF8877, 32);
if (receivedChar == 'g'){
Serial.println("WHITE 75% received");
client.publish("LEDStalamp/Response"," - WHITE 75% received");
irsend.sendNEC(0xFF48B7, 32);
if (receivedChar == 'h'){
Serial.println("WHITE 100% received");
client.publish("LEDStalamp/Response"," - WHITE 100% received");
irsend.sendNEC(0xFFC837, 32);
if (receivedChar == 'i'){
Serial.println("JUMP3 received");
client.publish("LEDStalamp/Response"," - JUMP3 received");
irsend.sendNEC(0xFF30CF, 32);
if (receivedChar == 'j'){
Serial.println("FADE3 received");
client.publish("LEDStalamp/Response"," - FADE3 received");
irsend.sendNEC(0xFFB04F, 32);
if (receivedChar == 'k'){
Serial.println("JUMP7 received");
client.publish("LEDStalamp/Response"," - JUMP7 received");
irsend.sendNEC(0xFF708F, 32);
if (receivedChar == 'l'){
Serial.println("QUICK received");
client.publish("LEDStalamp/Response"," - QUICK received");
irsend.sendNEC(0xFFF00F, 32);
if (receivedChar == 'm'){
Serial.println("FADE7 received");
client.publish("LEDStalamp/Response"," - FADE7 received");
irsend.sendNEC(0xFF10EF, 32);
if (receivedChar == 'n'){
Serial.println("FLASH received");
client.publish("LEDStalamp/Response"," - FLASH received");
irsend.sendNEC(0xFF906F, 32);
if (receivedChar == 'o'){
Serial.println("AUTO received");
client.publish("LEDStalamp/Response"," - AUTO received");
irsend.sendNEC(0xFF50AF, 32);
if (receivedChar == 'p'){
Serial.println("SLOW received");
client.publish("LEDStalamp/Response"," - SLOW received");
irsend.sendNEC(0xFFD02F, 32);
Serial.println();
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("ESP8266", "snokkie", "jiggiejiggie")) {
Serial.println("connected");
// ... and subscribe to topic
client.subscribe("LEDStalamp/Command");
message = "MQTT connected: ";
client.publish("LEDStalamp/Response",message);
} else {
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
void setup(){
irsend.begin();
irrecv.enableIRIn(); // Start the receiver
pinMode(PIN_IRSENSOR,INPUT_PULLUP);
pinMode(PIN_IRLED, OUTPUT);
// nothing to setup
Serial.begin(115200);
Serial.println("\n--START--");
WiFiMulti.addAP(ssid, password);
while(WiFiMulti.run() != WL_CONNECTED) {
Serial.print(".");
delay(500);
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
void loop(){
if (!client.connected()) {
reconnect();
client.loop();
currentMillis = millis();
if(currentMillis - previousMillis >= interval) {
previousMillis = currentMillis;
client.publish("LEDStalamp/Response"," - Still allive!");
if (irrecv.decode(&results)) {
// print() & println() can't handle printing long longs. (uint64_t)
serialPrintUint64(results.value, HEX);
Serial.println("");
irrecv.resume(); // Receive the next value
