AM-Transmitter for vintage AM (car-) radios
PCB_PCB_ESP_BT_AM.pdfPCBAdobe Portable Document Format - 54.56 kB - 01/20/2022 at 08:19 |
Schematic_ESP_BT_AM.pdfSchematicAdobe Portable Document Format - 55.12 kB - 01/20/2022 at 08:18 |
ESP_BT_AM.zipSource Files PlatformIO - ProjectZip Archive - 23.32 MB - 01/18/2022 at 13:32 |
So I designed the schematic, build it on a breadboard and after all works as expected - send it to fabrication.
One week later the PCB's arrived !
Let's assemble the first.
Step 1 - solder Resistors and Condensators
Step 2 - solder pin-headers for the PCM5102A-module
Step 3 - put the PCM5102A-module on the pin-headers and the pin-sockets for the ESP32-Devkit
Step 4 - solder the antenna-cable and put the ESP32-Devkit on
Now flash it - via PlatformIO - connect the antenna cable to your receiver, pair it with your smartphone (via BlueTooth), play some music and tune your receiver to the frequency - Voila'
I own some years an AMC Pacer X .... A great car (you know "Waynes World" ?) , but in my car there's is only a AM-radio.
Here in Old-Europe, esp. in Germany, aren't any broadcasting stations.... But to replace the radio with a new (modern) one ? Nope.
There's a device called "RediRad" you can buy, but ....
So there was the idea: Feeding the music through BlueTooth and then transmit it as AM.
No modification on the good old radio - only plug a cable in to the antenna connector, pair the device with your smartphone, tune the frequency and listen to the music !!
Inspired from two projects:
The 1st one outputs (prepared) sound via ESP32's DAC ... But this is only 8-Bit ... Huuuhhh
The 2nd is more promising: it uses a port-pin as open-drain and voila - you have a modulation.
So I'll do the 2nd ...
