I own some years an AMC Pacer X .... A great car (you know "Waynes World" ?) , but in my car there's is only a AM-radio.
Here in Old-Europe, esp. in Germany, aren't any broadcasting stations.... But to replace the radio with a new (modern) one ? Nope.
There's a device called "RediRad" you can buy, but ....
So there was the idea: Feeding the music through BlueTooth and then transmit it as AM.
No modification on the good old radio - only plug a cable in to the antenna connector, pair the device with your smartphone, tune the frequency and listen to the music !!
Inspired from two projects:
The 1st one outputs (prepared) sound via ESP32's DAC ... But this is only 8-Bit ... Huuuhhh
The 2nd is more promising: it uses a port-pin as open-drain and voila - you have a modulation.
So I'll do the 2nd ...
Druyve
