GNSS SDR Starter Kit (GNSS-SSK) is a series front ends(FEs) that are being used for GNSS SDR prototype development, signal and system teching. GNSS-SSK series have the capacity to digitize, acquire and track satellite signals from the full complement of GNSS systems, including GPS, BeiDou, Galileo, GLONASS.
GNSS-SSK contains one or two MAX2769s which can convert GNSS Upper L-band to low-IF or zero-IF samples. The signals L1/B1I/E1/G1 have been verified using SoftGNSS V3.0, GNSS-SDRLIB or GNSS-SDR software receivers.
FEATURES
One or two independent channel for GNSS IF sampling.
1~3bit I or 1~2bit IQ digitalization.
Bandwidth up to 18MHz.
Configurable RF/IF frequency, Filter, PGA, ADC and other parameters.
USB2.0 interface.
Sampling Application running on Windows.
