The first part of the signal seems to be a synchronization pattern. One bit has a length of ~325µs.
If I now know the sample/symbol rate the signal should be decoded.
A project log for Reverse engineering of an unknown 868MHz protocol
Reusing old 868 MHz equipment in openHAB
