After a bit of searching, I found the original API methods in the commands folder. I used
from commands.hub_methods import hub
to import them. Everything works as it should.
Then... I'm not sure what happened, but I plugged the Hub into my computer and connected it to the MINDSTORMS app and it made me update my hub. A little annoying, but okay. Afterward, on a lark, I tried to import hub using
import hub
and this time it worked.
I connected the hub to my Raspberry Pi and read the raw data being sent over the USB connection. The hub automatically sends status updates about the ports, the battery, and the IMU. This status update is sent about twice a second. Learn more here.
I played around with connecting over Bluetooth and had issues maintaining a connection with the hub to my Raspberry Pi 400. I read that others had the same issue as well. I came up with a solution but it involved reconnecting every time the connection was lost. Recently, I came across a Hub2Hub communication method and it uses a Raspberry Pi in its demo. I'm going to give it a shot and report back.
