It has been about two weeks since my last post. I got sidetracked with a few other projects, but I'm back on task. I was hoping to have the Microsoft MegaDetector converted into a MyriadX blob by now but I keep hitting stone walls. I have spent quite a bit of time trying to tweak the model optimizer parameters. I started out with the default parameters:
import blobconverter
blob_path = blobconverter.from_tf(
frozen_pb="/path/to/md_v4.1.0.pb",
data_type="FP16",
shaves=5,
optimizer_params=[
"--reverse_input_channels",
"--input_shape=[1,513,513,3]",
"--input=1:mul_1",
"--output=ArgMax",
)After some trial and error using the BlobConverter CLI and Luxonis MyriadX Blob Converter methods, I seemed to find what I believe are the correct model optimizer parameters.
frozen_pb="/Users/shadow/Desktop/OpenCV_Competition/MegaDetector/md_v4.1.0.pb",
data_type="FP16",
shaves=6,
optimizer_params=[
"--input_shape=[1,600,1024,3]",
"--input=image_tensor",
"--output=Softmax",
)The latest error states: "[ ERROR ] Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.CheckForCycle.CheckForCycle'>): Graph contains a cycle. Can not proceed." I'm going to try following OpenVINO's method for Converting TensorFlow Object Detection API Models.
If this method does not work I will examine other methods for achieving our goals.
JT
