All instructions are 16-bit wide (1 word), with optional extension of 16 more bits for immediate value needed for some of these instructions.
Bit patterns for the instruction types: bits in instruction word: FEDC BA98 7654 3210 [extension] ALU: 1xxx xxxx xxxx xxxx Load/Store via Mem Pointer: 011x xxxx xxxx xxxx xxxx xxxx xxxx xxxx Load/Store via direct addr: 010x xxxx xxxx xxxx xxxx xxxx xxxx xxxx MOV: 0011 xxxx xxxx xxxx Load immediate value: 0010 xxxx xxxx xxxx xxxx xxxx xxxx xxxx Jumps: 0001 xxxx xxxx xxxx xxxx xxxx xxxx xxxx Address Arithmetic: 0000 1xxx xxxx xxxx xxxx xxxx xxxx xxxx Miscellaneous ops: 0000 0xxx xxxx xxxx
All the 'x' places above can be either 0 or 1, depending on particular instruction.
The extension word with immediate value is always present for Loads/Stores via direct address, Loads of immediate values and Jumps, while for the Loads/Stores via Memory Pointer + offset and Address Arithmetic instruction types it is optional, and depends on particular instruction. Thus, although I tried to make the ISA RISC-like, it has some elements of CISC in a sense that not all instructions are the same size.
