Loading hard coded value into one of the registers.
The instruction is 2 words (32bit).
There are 2 types of this instruction - one for loading a word (16bit) into General Purpose Register, and other for loading a double word (32bit value in range 0x00000000 - 0x01ffffff) into a pair of Memory Pointer registers.
Here are layouts:
Instruction words: bits of word #1 bits of word #2 Mnemonic: FEDC BA98 7654 3210 FEDC BA98 7654 3210 LDir rX 0xffff 0010 0ddd xxxx xxxx vvvv vvvv vvvv vvvv LDim MP 0x01ffffff 0010 1ddv vvvv vvvv vvvv vvvv vvvv vvvv d - bits of register address (X or MP) v - bits of data value to be loaded x - "don't care" bits - have no effect on result rX - General Purpose Register #X MP - Memory Pointer register pair, one of Program Counter (PC), Stack Pointer (SP), Frame Pointer (FP) and Base Pointer (BP)
There are no corresponding Store Immediate instructions, as it is has no practical use -- the write will be into program area at address that cannot be readily predicted and utilized at code writing time.
