Motors and encoders of both wheels are fully connected and operational. An ISR is used to count the pulses for each encoder.
Can enter the speed at which the motors rotation (0-255) and direction of rotation
Motor A seems to consistently rotate faster than Motor B for the same PWM value. I will investigate this issue at a later date.
