Audio waveform and frequency spectrum display program. Audio input is from an
Electret mic with pre-amp circuit. Frequency response is only around 8kHz. No
anti-alisaing filter so, may get erroneous values at higher frequencies.
Although this runs on Arduino framework, a higher power MCU is needed than
standard Arduinos. In this case using an STM32 Nucleo32 dev board was used NUCLEO-L432KC. If you cannot find this board, then another STM32 with at least 80MHz clock rate is fine.
Hookup
DISPLAY
CS -> D6
DC->D9
RES->D10
SDA->D11
SCL->D12
Vcc - LEAVE UNCONNECTED
MIC - output ->A0
Switch - GND and to D4
I used platform.io for development.
