Using this logger I determined that the issue with my headlights must be in the ballast for the HIDs - because the voltage at the connector for the headlights remained in the expected range during driving despite the headlights flickering.
A project log for Portable Arduino Power Datalogger
USB powered data-logger that saves voltage and current measurements to a micro SD card.
