Petoi Coding Blocks Released For Block-Based Programming Support
A project log for OpenCat - Open Source Quadruped Robotic Framework
OpenCat is the open-source Arduino and Raspberry Pi-based quadruped robotic pet framework for Boston Dynamics-styled programmable robots
petoiPetoi 05/01/2023 at 09:250 Comments
Petoi Coding Blocks Released for Block-based Programming Support
Petoi is proud to release Petoi Coding Blocks, a new way to program the Petoi robots. It's a drag & drop programming environment similar to MIT Scratch and supports Mac, Windows and Linux.
In case you wonder how it's different from the other block-based programming environment Tinkergen:
Petoi Coding BlocksCodecraft by Tinkergen
OpenCat supportcompatible with OpenCat 2.0 and all Petoi robot petsonly compatible with Bittle running on OpenCat 1.0 which is no longer updated
Connection typewired and Bluetooth connectionwired connection
Underling code implementation generationit uses the Python API and can generate Python codes that students can studyit uses the C++ API and can generate C++ codes that students can study
Free curriculumcoming in mid Mayavailable
We highly recommend you using Petoi Coding Blocks now.
Rich text editor
