Recent updates
A project log for Y-maze to study cognitive abilities in insects
An affordable and easy to make instrument to train and test fruit flies
wrijuWriju 03/18/2022 at 17:480 Comments
I completed the shock generator circuit(with a few modifications). I will post the circuit schematic shortly.
The lights(RGB LEDs) were housed inside the rubber plungers using a small plastic insert.
The copper foil tape etched interdigitated grids were rolled into two syringes with the ends sawed off.
