Understanding how it works
A project log for Controlling a cctv camera with arduino!
A dream school project: control one or more cctv cameras with only a arduino
pixelboPixelbo • 02/17/2022 at 08:29•0 Comments
Hello again, here a couple of images where I try to explain to you how it works:
The response from the camera
If you can see well, between the TX- and TX+, there is a 2V coming from the rs485 module, it is a "problem" because when the camera responds at the query on the same pair of wire, the signal from the camera is cut out by this 2v (lowered to a volt difference about 200mv).
I'll figure something out for next time!
See you next time !
