Hello!
I've made some big modification to my Arduino library.
It can now control the camera with only one module with the switching of the RE and /DE pin on the module.
I haven't tested yet all feature, so I can't say for sure if it works but here is what the library should do:
-Sending a basic command with reception of the acknowledgement message from camera
-Sending a query and decoding properly the response
-Sending a raw text command like so: "FF 01 00 04 3F 00 44"
It is already the end of the log, a short one for sure but be sure to check the github!
Next I'll build a mini desk control to test all feature!
Pixelbo
