![](https://cdn.hackaday.io/images/5505581645634257958.png)
Still in stability testing by leaving the breadboard circuit by the window.
It was a bit cloudy day but from the log, the device successfully has completed 6 episodes (24 min each * 6 = 144 minutes) of EE. Also based on the battery voltage observed, the battery has been charged in total eventually.
![](https://cdn.hackaday.io/images/original/1375711645634203580.gif)
