Let's try this again - natively this time
A project log for My Adventure to Compile Cura From Source
An attempt to compile Cura to be able to contribute solving a slicer engine issue that has been present for many years.
timo-birnscheinTimo Birnschein 02/20/2022 at 20:110 Comments
Instead of following a the cura build environment that's supposed to set everything up for you, I'll go the other route and set everything up myself this time. I have most of the stuff installed already, anyways, so this might yield better results.
Following this and ignoring the first step: https://github.com/Ultimaker/cura-build
This is getting old quickly:
Moving over to Ubuntu.
