Before I start developing GUI for PlainDAQ, I wanted to see how far I can push matplotlib
It can run at 60 FPS if you push it to its limits, which is more than I need.
There are occasional hiccups, but I think it's fine.
Here is the code if you're curious:
https://github.com/AlperenAkkuncu/PlainDAQ/blob/main/Development/GUI/sinewave_stress_test.py
The graph is embedded in tkinter because I am thinking about developing the GUI with tkinter and matplotlib.
