The wiring represents the top panel in the Frame; the support cubes and Rockwool are the bottom panel. The wiring is High Temp Fiberglass Insulated wire and high temp terminal rings.
A project log for DesignLab Builds: Heat Press
2022 Hackaday Prize Recycling Machines Inspo
