We wanted to mount the Eboxes to the frame in a way that would be relatively easy to mount and also remove... using hose clamps seemed to be a good option... so far so good! The brackets did require a mill to machine the grooves for a well for the Press Frame and a little recess for the width and thickness of the hose clamp itself.
