The ESP32-S3 is the first Espressif board that has both true USB and Bluetooth, so naturally you have to wonder if it's any good for keyboards. I decided to try and see.
I'm using @Unexpected Maker's TinyS3 boards that just arrived from Australia, hence the board's name. And the fact it's shaped a little bit like a sandwich, if you squint a little.
It's also my first board where I'm using switch sockets, so you can rearrange and replace the switches on it as you like.
deʃhipu
Kārlis
mr. mosby
I just wasted a whole day trying to track that Not Implemented error. Trying to roll back firmwares guessing at when Adafruit's "Deep Dive w/Scott" when he allegedly had it working.
Was convinced they just broke something in _bleio, but nope. It's never worked ig.
At least now I know I'm not insane and can just buy an nrf.
