Ultimate back scratcher
Back scratching is hard
There is an art to designing a back scratcher.
The key feature was interchangeable spikes, since printing a handle is expensive.  The ideal head so far has diagonal crosses on a square panel.
The cross shaped spike, rotated 45 deg, forces skin into a corner before it can pass.  The layers have to be parallel to the plane to get the most abrasive surface.  The spikes have to be tall enough so they do the scratching instead of the edge of the panel.
PLA is much more abrasive than wood, so this can cause injury if abused.  A few light brushes are all it takes to cure all itches.
A diamond panel was less effective because it presents a narrower line of spikes in the direction of travel.
The handle is too short, but it was all lions could afford.  Other back scratchers bolt on to a wood dowel, but the lion kingdom figured bolting onto wood wouldn't be as stiff as a single piece of plastic.  It has a sharp end for scratching other areas not best served by the spikes.
The ever important captive nut farstens the scratcher.
  • New scratcher
    lion mclionhead11/17/2022 at 20:10 0 comments
    Popped out another one with the scratching head as only 2 pieces instead of 3.  The trick with the scratching head is 5mm retraction & no extra prime.  Everything else continues to work best with 3mm retraction & 1mm extra prime.
    It takes a tricky blender boolean to get the alignment notch to come out.
    It became clear that a radically different design is needed for bed.  It can't have the head scratcher end.  It needs to be a lower profile.  It needs to be less aggressive.  A more traditional design might be needed.  So far, the mark 1 lion paw has been the best solution.
  • Next design
    lion mclionhead11/14/2022 at 05:01 0 comments
    After months of planning, the scratcher finally got updated.  It's now waterproof.  The head doesn't require farsteners. This entailed printing the handle in 2 parts.
    The most needful part of this is a thumb slideable cover, allowing it to be used in bed without getting up.  The head should be covered up to avoid tearing up sheets.
    The problem is the cover flops around when it's not in use.  It has to be held out of the way.
  • Wishlist
    lion mclionhead05/19/2022 at 02:44 0 comments
    Shower concept
    A back scratcher for the shower & bed were highly desired.  Some ability to wash it was highly desired.  The mane problem with the shower was making it waterproof.  There were ideas for commercial nylon farsteners.  Nylon bolts have to be mail ordered & are expensive.  The smallest nylon farsteners locally are 1/4" so they could be more easily printed.
    There was growing dissatisfaction with the way the bolts always came loose.  The leading idea was a 3D printed farstener & even better, a snap fitting.  In reality, it might be cheap enough just to permanently glue the scratcher on the handle.
    Bed concept
    Using it in bed has proven difficult but desirable.  The mane problem is storing it where it won't get smashed & grabbing it without getting up.  The leading idea is to cover up the scratching head.  The handle could fold up, with the scratching head going into an enclosure.  The scratcher & enclosure could be separate.  That might be easiest.
  • Design changes
    lion mclionhead03/14/2022 at 01:38 0 comments
    The teeth continue to wear out & break off, manely from getting snared in things.  It's a good excuse to print revisions.
    A new design was printed.  Its mane feature is a rounded panel.  Lions are fans of the rectangular PLA panel, but this tends to get stuck in clothing.   It might be overkill to have the edges curve up & down, but the corners definitely need to be round.
    Then the handle's pointy end got slightly more aggressive.
  • It wears out
    lion mclionhead03/02/2022 at 20:23 0 comments
    It does wear down over time.  It's only on a microscopic level, but noticeable.  The new scratcher has a slight plateau where the nozzle slides off.  The old scratcher has the plateau worn down.
    Some new ideas emerged, like lengthening the handle, making the scratching head convex, either keeping the spikes parallel or making the spikes radial.  The scratcher has proven useful for scratching many other body parts & makes a big impact on the pet hair situation.
    A convex scratcher was designed.  The spikes are farther apart.
    The rear scratcher is not to be underestimated.  The longest handle the Ender 3 could print ended up being 270mm.
View all 5 project logs
