A project log for Wireless IMU body tracker
Small battery-powered IMU tracker that could be used for motion capturing or to control robotic arms.
Hey, sadly i lost all the files when switching pcs :( If it is any help all the code was made from 2-3 open source projects and arduino libraries so just search for the parts i used and you should be able to replicate this.
Looking good, could you possibly publish the code please?
Yes, delete it Cancel
