I tried to hold a 29cm long box similar to how Tetent will be held and I felt that it was probably best if I kept #Leti, the Tetent UMPC, at around 30cm. Considering that the current motherboard options take up 80 - 90mm, there's only a few mm available with the current 93mm length, 52mm active length Tetrinsics. Thus, I've reverted back to the 1.47" Tetrinsic.
To stay in the 230mm of availabe space in #Teti [gd0022] without having to make the entire enclosure longer, the 80mm samsung speaker wasn't going to fit. Instead, I'll be implementing a stereo soundsystem with these:
