[T] Focus on solar version? Include reverse PDLC film?
A project log for Tetent [gd0090]
A water resistant, 300WPM input peripheral for end-to-end workflows.
kelvinakelvinA 08/21/2023 at 12:380 Comments
Since
I'm thinking of focusing on the solar version going forward and, once I've got a Tetent that works, consider engineering an LCD backlit solution.
It might also be possible to find a reverse mode PDLC sheet and, coupled with LEDs on the edges of the acrylic / lexan window, allow the choice of absorbing ambient light energy or a solid white LED backlight. The reason for the inverse/reverse mode sheet is because normal PDLC film requires energy to become transparent. This is the kind of PDLC I need:
It seems that the name for this material is "PNLC film":
