Following the arrival of the nuts and bolts, I've just designed and have started printing the carraige that uses 608 bearings to slide on the 42.4mm tube.
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
