AIO II Issues
A project log for SecSavr Sublime [gd0036]
An FFF 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution"
kelvinakelvinA 04/05/2022 at 13:230 Comments
I can't seem to get the extruder motor to move on the AIO II. It uses some ST820 drivers and the AIO wiki doesn't tell me what resistors or logic voltage it uses for me to use the equation on the ST820 drivers.
Thus I'm going to get the Octopus Pro set up. This will also be a good chance to try the S6609s at 36V.
