I'm thinking that SecSavr is really just a motion system and enclosure agnostic enough to justify having a name (and subproject for), just like the main effector SecSavr Slime [gd0088], filament selector #SecSavr Select [gd0091] , extruder SecSavr Slight [gd0091] and the Hexadecibel.
The reason why the above enclosure configuration is called the SleepCinema is because this printer is designed to fit around a small double bed (120*190cm) and have a projector installed which will cast on the short wall furthest away from the camera. There's supposed to be light in that section so that you can see it, but the fusion 360 renderer didn't co-operate. Thus, the middle section looks like a black panel, even though it's the same as the bronze panel above.
Due to space constraints (which I reffer to as The SpaceApp), I'm expecting the doors to slide open and hang off to the side. There are 3 other constraints -- CostApp, PowerApp and CanDoTheTaskApp -- that all need to pass to obtain a solution.
