Since my designs are both dependent on form and function, as well as other parts of the design, I've been hitting a few too many unknowns while trying to compute a solution for the tool bar and axis sliders.
Tool Bar
I've gone with the idea of having the #SecSavr Select [gd0091]'s inside a main body that looks like a bracket (see my logo), along with the electronics (not including PSU's. I'm not sure how the tool bar is going to be moved, so I'm just going to assume via stepper motors and push forward. Originally, I was thinking of having the reverse bowdens go around the back, but I thought about accessibility issues and so moved it to the front (only 4 bowdens are drawn). Actually, now that I write this, I've realised that I forgot about the tool part of the tool bar. I'll have to sketch more.
130mm is the height the Selects are likely to be, so I went with that. I've also thought about how to aesthetically split up the part for printing, building and maintenance.
Sliders
The Y slider had to be extended so that the steppers could fit, and now it doesn't look good, so I've drawn a redesign.
For both sliders, I'm thinking of a white and black contrast print, and have shaded accordingly.
