[M] SleepCinema tweaks
A project log for SecSavr Sublime [gd0036]
An FFF 3D printer that I described as The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution
kelvinakelvinA 07/14/2022 at 04:400 Comments
Due to developments with the SecSavr Suspense project, I've moved the Z axis beams closer to the sides of the SleepCinema to make room. I also removed all the extra Slights from the Tool Bar to improve performance.
