I started designing the SecSavr Select inside the SecSavr Space file, so I've moved it into its own file and I am currently in the process of cleaning it up / adding groups before finishing the design. Below is an old gif I recorded. It shows what happens when the servo motor goes through 300 degrees of motion (out of 320).
