I decided to machine the condenser lenses in the mini lathe.
It was way harder than I imagined I also had to split the U shaped pole piece into two.
To reach the best surface finish I created a grinder attachment to the lathe and used it to reach final dimension. But this is the diameter limit of the mini lathe I am using machining with carbide inserts.
But the lathe cleaning was the worst part afterwards :D
